AutoCAD Electrical Forum
Source/Dest. Arrows with source & destination
0 REPLIES 0
Message 1 of 1
137 Views, 0 Replies
Is there a way to have the source and destination arrows show the device and pin number the signal is going to/coming from along with or in place of the wire number?
I've noticed in the Terminal Block Editor, they use a %Q:%P code to display wire destination information in a terminal layout, and it would be nice if I could have something similar to this appear as part of my off-page references, since you can see where the wire is going/coming from without actually needing to look at the destination sheet.
Thanks.
Andrew Hand
If %Q:%P won't work, is there a way to display the wire connection sequence on the drawing as, text, an attribute or part of a wire number?
0 REPLIES 0
”Boost
