AutoCAD Electrical General Discussion
Distinguished Contributor
april_herr
Message 1 of 10 (105 Views)
source arrow
105 Views, 9 Replies
12-05-2011 03:43 PM
I am trying to modify the from/to source arrow blocks.  I am not able to save or create a new block from these files.  I've tried saving as something else, etc.  I have had some save problems in the past, so I'm not sure if this is an extension of that.  Should I be able to modify text in those files?
*Expert Elite*
testsubject
Message 2 of 10 (95 Views)
Re: source arrow
12-06-2011 04:48 AM in reply to: april_herr
Most definitely. You should be having no problem with saving these. They are normal ACAD dwg files.
Bob Hanrahan
Ace User since 1998
april_herr
Message 3 of 10 (87 Views)
Re: source arrow
12-06-2011 07:12 AM in reply to: testsubject
This is so strange because I can copy and save the file as many times as I want, until I modify it.  I build the block and it seems to work just fine, but if I insert after closing block editor,nothing has changed and the file is not in my directory.
Last time I was having save problems, we finally came to the conclusion I didn't have the correct permissions.  After that was taken care of, I didn't have any more problems until now.  This is SO frustrating!  Any advice would be welcome!
By the way, I have checked my permissions and all is well  :smileysad:
*Expert Elite*
testsubject
Message 4 of 10 (83 Views)
Re: source arrow
12-06-2011 08:42 AM in reply to: april_herr
Wait a minute. Are you using the block editor to do this? I would recommend that you just copy the source drawing you are trying to modify and change it like you would a regular .dwg file because that is all it is. I do not like using Block Editor because of this very reason; you thought you made a change to the block but in reality, it is probably only changing the block locally in the drawing you have it located in.
Then when you insert a source arrow, go to the folder that the new dwg is located in and insert that.
Try that and see if it works. We can go on from there if you are successful.
Bob Hanrahan
Ace User since 1998
april_herr
Message 5 of 10 (81 Views)
Re: source arrow
12-06-2011 09:31 AM in reply to: testsubject
Ok, I modified the dwg, but I'm unsure how to get the source arrow from that file.  Do I just insert as a regular block without using the source arrow tool?
*Expert Elite*
testsubject
Message 6 of 10 (79 Views)
Re: source arrow
12-06-2011 10:11 AM in reply to: april_herr
April,
Okay now when you go to insert a Source/destination, youu can override the project defaults and select the Signal Arrow Style on the right hand side of hte dialog box. I should have told you earlier to rename the new source code and replace the number ( if I was using Arrow style 1 the old name would be HA1S4 and the new name would be HA6S4).
The 6 corresponds to the 6th arrow style. The arrow styles 6-9 are for user use to modify as you see fit.
Everything should work like you are used after this.
Bob Hanrahan
Ace User since 1998
april_herr
Message 7 of 10 (77 Views)
Re: source arrow
12-06-2011 10:27 AM in reply to: testsubject
Awesome! That works great! :smileyvery-happy:
Next question:  I am re doing all of the symbols and blocks to look like what we use here.  It has been quite the undertaking, but I feel like my organization needs help.  I eventually want to use the new library only, but is that going to mess with any of the commands?
Thanks for all your help!  I couldn't have done 1/4 of what I've accomplished without this discussion board!
April
*Expert Elite*
testsubject
Message 8 of 10 (74 Views)
Re: source arrow
12-06-2011 10:38 AM in reply to: april_herr
Not really. As long as you use the same names for the new components and locate them in the new folder I told you to set up earlier, it should be pretty seamless. When you go to insert a part, it will get it from the new folder first if it exists there and if it doesn't it will then "roll" down to the next folder in the project properties unitl it finds the symbol.
If you want to stick with the "1" styles, move your new source/destination code dwgs to the company specific folder and leave the names the same.
Bob Hanrahan
Ace User since 1998
april_herr
Message 9 of 10 (71 Views)
Re: source arrow
12-06-2011 12:16 PM in reply to: testsubject
My next question concerns the tb blocks we use in the panel layout.  In the "panel" folder that came with the software, all the tb's are named "ut4", "uk10", etc and I don't see part numbers anywhere.  How will the BOM recognize those names?  I set up a panel layout and the BOM just has PHOENIX as the MFG but no part number.  As a company, we set up blocks named by the part number.  How should I go about doing this?
april_herr
Message 10 of 10 (64 Views)
Re: source arrow
12-06-2011 02:41 PM in reply to: april_herr
I just started to tweak the files provided for tb's and I came across one I can't find.  It is a ut4 gnd.  If I do a catalog lookup, I find it and can insert the block.  I would like to redo that file. The block name is PNLAC9B.  I have done a search and not found this file.  If I insert a second one, the block name is PNL9BB.  How do I get this to be like the other parts?  I'm sure this isn't going to be the only one I have trouble with...
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
