Source and Destination arrows are snapping to the midpoint of wires instead of the ends. When I try to edit, using the "edit component" right-click menu, I get an error message, "No LINE "wire" tied to this Source/Destination marker"
I've tried deleting the components and wires, redrawing the wiires and then inserting new source/destination arrows. Each time I geet the same result.
Solved by testsubject. Go to Solution.
Try turning off OSnaps (F3). Autocad Electr4ical does not play nice with OSnaps. I would recommend not using them at all...
