I am missing something with Wire/Wire types. I have created a basic list in my drawing for wire type, size and color. As I work through a schematic I need to add more wires with the wire information. My wire list is so long I would like to be able to sort them. The intent is that I have a group of white wire size 8AWG- 14AWG on wire table reference 1, 2, 3, 4. The next available wire table entry is wire table reference 200. Can I insert a blank row at table reference 5 to add a white 16AWG or can I add the wire at 200 and then sort the table to force the 16AWG info up to line reference 5? The Help file Create/edit wire Type tells me “Use the grid control to sort and select wire types to modify”. I don’t see the tool to use for a sort function.
Thank you
Solved by TRLitsey. Go to Solution.
Solved by drathak. Go to Solution.
It is a bit counter-intuitive. With most grid controls a single click on a header does the sort. With that grid, you have to double click it.
See if that helps.
Well, there is my slice of humble pie today. Thanks Drathak.
@TRLitsey wrote:Well, there is my slice of humble pie today. Thanks Drathak.
And I learned something today. Must be time to go home.
Actually I just stumbled across that. Boo to Autodesk for using a non-standard grid control.
