Solved by jminch. Go to Solution.
I'd like to have all fields available in the BOM report, just like in the Component report.
I tried to edit BOM sorting fields manually in BOM format file opened in Notepad, but it doesn't work.
User post is not available in Automatic reports.
Vladimir
Hello Pat,
My name is Jay and I also am interested in sorting by something other that the four default choices. I would like to be able to sort by TAGS. I haven't done any kind of lisp programming. I also know that I can export to an excel spreadsheet, but I want to put this on a drawing. The information that I want to put on the drawing is as follows: TAGS CATALOG MFG DESCRIPTION QTY SUB. The report I am using is the Panel Report - Bill of Material.
Thank you for your time,
Jay
Hi Jay,
Change the Report format to "Display in "BY TAG" Format"
James
