upscale
Try it on an attribute that does not contain a decimal ( . ) point and
see if it will work then. Let us know......
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"upscale" wrote in message
news:8708197.1074630155961.JavaMail.javamailuser@localhost...
> I have been trying to get this to work, but with no luck, I still keep
getting a nil value. The block is there, the attribute is there but no luck.
Has anyone been able to do this?
> Example: (c:wd_getattrval titleblock "31003.1")
> Retrieve an attribute value from a block insert:
> (c:wd_getattrval ( comp_en attrname )
> comp_en = entity name of block insert
> attrname = attribute name to find and retrieve
> RETURN = attribute value (or nil if attribute not found)
