I have 4 sheets that have signals arrows on them linking only these 4 sheets, that is no signal that go off these 4 sheets. I need to copy these 4 sheets to create 5 groups the problem is when I copy the sheet using the Copy to I get the new sheet all the components label correctly but the signal arrows have the same signalcode now I get errors that state I have multiply source arrows.
Is there a way to copy a sheet and get new signalcode while coping or is the only to delete all signal before coping the sheet?
Solved by dougmcalexander. Go to Solution.
I have a utility I sell that automatically increments signal codes when they are inserted as part of a saved circuit. There is a video that shows it in action on the Tips/Tricks page of my web site.
Thanks the vidoe showed me a way to change the signal code that will get me by for now.
Glad to help. Please mark as a solution if it solved your issue. Kudos are welcomed as well.
