AutoCAD Electrical General Discussion
New Member
MICHEL
Message 1 of 3 (186 Views)
SIGNAL SOURCE/DESTINATION
186 Views, 2 Replies
04-14-2004 05:00 AM
Is there an easy way, after having created a source and destination signal, to switch them?..ie source becomes destination and vice a versa.
*Nate Holt \(Autodesk\)
Message 2 of 3 (186 Views)
Re: SIGNAL SOURCE/DESTINATION
04-17-2004 08:03 AM in reply to: MICHEL
Michel, You can swap them but it's not easy. Here's how: 1. Get the block name of the symbol (use DDATTE or LIST). Block name for source arrows will be something like "HAxSy" where "x" = "style" number and "y" = 1 for wire from right, 2 above, 3 from left, 4 from below. For a destination arrow symbol, it will be "HAxDy". 2. Use the AcadE SWAP BLOCK command and select "Swap a Block - one at a time" and "Pick new block from icon menu". Hit OK. 3. The icon menu dialog should display. In lower left-hand corner type in the new arrow block name, flipping the state of the 4th char of the block name from "S" to "D" or "D" to S" (example: if existing signal block is "HA1S2" then type in "HA1D2" to flip to a destination arrow). Hit OK. Maybe we should think about making the "Toggle NO/NC" command usable on these signal arrow symbols? Nate. "MICHEL" wrote in message news:24314679.1081944074526.JavaMail.jive@jiveforum2.autodesk.com... > Is there an easy way, after having created a source and destination signal, to switch them?..ie source becomes destination and vice a versa.
*John Pullen
Message 3 of 3 (186 Views)
04-20-2004 06:44 AM in reply to: MICHEL
I like the idea of the Toggle command except that it becomes confusing to have so many functions on a single icon... I find it hard to remember that it does that, especially when not often used. How about a swap button on the edit dialog also? (I had a user request for this just this week too.) John Pullen "Nate Holt (Autodesk)" wrote in message news:40814771$1_1@newsprd01... > Michel, > > You can swap them but it's not easy. Here's how: > > 1. Get the block name of the symbol (use DDATTE or LIST). Block name for > source arrows will be something like "HAxSy" where "x" = "style" number and > "y" = 1 for wire from right, 2 above, 3 from left, 4 from below. For a > destination arrow symbol, it will be "HAxDy". > 2. Use the AcadE SWAP BLOCK command and select "Swap a Block - one at a > time" and "Pick new block from icon menu". Hit OK. > 3. The icon menu dialog should display. In lower left-hand corner type in > the new arrow block name, flipping the state of the 4th char of the block > name from "S" to "D" or "D" to S" (example: if existing signal block is > "HA1S2" then type in "HA1D2" to flip to a destination arrow). Hit OK. > > Maybe we should think about making the "Toggle NO/NC" command usable on > these signal arrow symbols? > > Nate. > > "MICHEL" wrote in message > news:24314679.1081944074526.JavaMail.jive@jiveforum2.autodesk.com... > > Is there an easy way, after having created a source and destination > signal, to switch them?..ie source becomes destination and vice a versa. > >
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
