AutoCAD Electrical Forum
SIGNAL SOURCE/DESTINATION
2 REPLIES 2
456 Views, 2 Replies
Is there an easy way, after having created a source and destination signal, to switch them?..ie source becomes destination and vice a versa.
2 REPLIES 2
Michel, You can swap them but it's not easy. Here's how: 1. Get the block name of the symbol (use DDATTE or LIST). Block name for source arrows will be something like "HAxSy" where "x" = "style" number and "y" = 1 for wire from right, 2 above, 3 from left, 4 from below. For a destination arrow symbol, it will be "HAxDy". 2. Use the AcadE SWAP BLOCK command and select "Swap a Block - one at a time" and "Pick new block from icon menu". Hit OK. 3. The icon menu dialog should display. In lower left-hand corner type in the new arrow block name, flipping the state of the 4th char of the block name from "S" to "D" or "D" to S" (example: if existing signal block is "HA1S2" then type in "HA1D2" to flip to a destination arrow). Hit OK. Maybe we should think about making the "Toggle NO/NC" command usable on these signal arrow symbols? Nate. "MICHEL" wrote in message news:24314679.1081944074526.JavaMail.jive@jiveforum2.autodesk.com... > Is there an easy way, after having created a source and destination signal, to switch them?..ie source becomes destination and vice a versa.
I like the idea of the Toggle command except that it becomes confusing to have so many functions on a single icon... I find it hard to remember that it does that, especially when not often used. How about a swap button on the edit dialog also? (I had a user request for this just this week too.) John Pullen "Nate Holt (Autodesk)" wrote in message news:40814771$1_1@newsprd01... > Michel, > > You can swap them but it's not easy. Here's how: > > 1. Get the block name of the symbol (use DDATTE or LIST). Block name for > source arrows will be something like "HAxSy" where "x" = "style" number and > "y" = 1 for wire from right, 2 above, 3 from left, 4 from below. For a > destination arrow symbol, it will be "HAxDy". > 2. Use the AcadE SWAP BLOCK command and select "Swap a Block - one at a > time" and "Pick new block from icon menu". Hit OK. > 3. The icon menu dialog should display. In lower left-hand corner type in > the new arrow block name, flipping the state of the 4th char of the block > name from "S" to "D" or "D" to S" (example: if existing signal block is > "HA1S2" then type in "HA1D2" to flip to a destination arrow). Hit OK. > > Maybe we should think about making the "Toggle NO/NC" command usable on > these signal arrow symbols? > > Nate. > > "MICHEL" wrote in message > news:24314679.1081944074526.JavaMail.jive@jiveforum2.autodesk.com... > > Is there an easy way, after having created a source and destination > signal, to switch them?..ie source becomes destination and vice a versa. > >
”Boost
