AutoCAD Electrical Forum
Signal Source and Destination Arrows With PLC Spreadsheet I/O Utility
3 REPLIES 3
Outbound
517 Views, 3 Replies
When using the Spreadsheet to PLC I/O Utility, I am unsuccessfully attempting to place source and destination arrows.  I am attempoting to place a source arrow and a destination arrow on the same line.  I can do this manually on the drawing with no problem.  However, when IU attempt to place a source and destination arrow on the same address line, using the spreadsheet, either the source or the destination wire connection drops out.
What can I do to add souce and destination arrows via the PLC spreadsheet
3 REPLIES 3
testsubject
in reply to: Outbound
The drawing you sent out was blank.
Could you resend it so I can take a look at it?
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
electricman1
in reply to: testsubject
Try these in the DxBLK field:
"HA1D3" - Destination arrow for input cards
"HA1S1" - Source arrow for output cards
You may also add the signal code in DxTAG fields to save time. Be sure to use a unique signal code for each arrow.
Don't forget to try RackLayout.com when creating the Excel sheet.
Outbound
Sorry...I failed to attach the sample file properly.
Hopefully, it willbe attached, here.
”Boost
