When using the Spreadsheet to PLC I/O Utility, I am unsuccessfully attempting to place source and destination arrows. I am attempoting to place a source arrow and a destination arrow on the same line. I can do this manually on the drawing with no problem. However, when IU attempt to place a source and destination arrow on the same address line, using the spreadsheet, either the source or the destination wire connection drops out.
What can I do to add souce and destination arrows via the PLC spreadsheet
The drawing you sent out was blank.
Could you resend it so I can take a look at it?
Try these in the DxBLK field:
"HA1D3" - Destination arrow for input cards
"HA1S1" - Source arrow for output cards
You may also add the signal code in DxTAG fields to save time. Be sure to use a unique signal code for each arrow.
Don't forget to try RackLayout.com when creating the Excel sheet.
Sorry...I failed to attach the sample file properly.
Hopefully, it willbe attached, here.
