With assistance I've received here, I'm reasonably comfortable with putting signal names on drawings, there are so many options. My next challenge is getting them on reports. I don't see the connector XREFs or Desc in the Change Report Format dialog box.
What I want is a report that says A1J/P1 has Signal 001 and goes to A2P/J1.
The intent is to give the board designers their interfaces so they can design the boards.
I've attached a simple .dwg, if there are better ways to achieve graphically and report wise, I'm open to suggestions.
Thanks!
Solved by ocean1. Go to Solution.
If you're NOT using wire numbers for anything else, I guess you could use the wire numbers as a signal name, and run the fron/to report like this:
Or maybe you can use a cable marker, where the "color" is the signal name instead, and then run the cable from/to report?
I have to agree with the cable route. Since that is probably a ribbon cable or some sort of cable between the connectors, it needs to be defined too.
My apologies for not replying earlier, I had gone on to other aspects of the job.
I'm reluctant to monkey with the signal names. After I am through, I pass the dwg on to other designers who do the wire and cable specification work.
For signal names, I've opted to use the TERMDESCnnJ XREF. It looks nice on the drawings for the reviews and stays out of the way oof the folks who do the work. When I figure out the database aspect, I can dump into the lower level configuration item specifications and upper level requirements.
I've attached a sample of the work and what I'd like to see. What I'd like is a report that correlates the signal names with their associated connector pins. I'd expect to see a field in the report options named TERMDESC that I can add as a column, but I don't see it. I'm using ACE2012 on my work computer.
If it's not report material, I can pull it out of the project database if I knew where it was. The ACE2012 help shows a path through the tool menu palette, but I do not see anything under the tool menu that says database.
Thanks for any assistance and Happy Holidays, particularly to those of you working the forum today!
