I know this is a old post I want to do this with 2014 and it does not work. Would like to have just the description and ref on one line with a "/" bewteen them
@dltimmons wrote:I know this is a old post I want to do this with 2014 and it does not work. Would like to have just the description and ref on one line with a "/" bewteen them
I'm still on 2013, so I can't speak to why that doesn't work. (It should.) Are you sure you only have one copy of those symbols and it isn't grabbing the unedited ones?
But as for changing how the description and cross reference are displayed, you would still need to edit all the blocks. Make the DESC1 attribute right aligned, then add a "/" symbol by itself, then put the XREF attribute after that and make it left aligned. With a little experimenting and tweaking you should be able to get what you want. (Are you sure you want the DESC1 or maybe the WIRENO instead?)
See the attached image for what I mean.
We making the change from Promis*E We liked or got use to the way it did signals, The signal code was a little confusing at first till figure our to use the use button and let AcadE set the signal code.
After three or four rounds of Purge and Swap/update Block it finnally started working. I got it down to Desc1 on one line and Ref on a second line that is a better fit for us. We do not want the wire number at the signal arrow.
@dltimmons wrote:Thanks
Cool. And that is what customization is all about.
