AutoCAD Electrical Forum
Showing Terminal Block Jumpers in Schematics
3 REPLIES 3
LOUBRA
5197 Views, 3 Replies
(using AutoCAD 2014)
Hello ACADE Community,
Before I start, I did comb through the forums trying to find a solution to my problem but I didn't find anything.
Let's say I build a terminal strip using two-tier terminals for power distribution.  (In the image below, terminal 100 and 101 are associated, 100 being the TOP level and 101 being the BOTTOM level, I want to jumper the odd terminals with the odds, and the even with the even)
Then I go to my Terminal Strip Editor and associate the terminals and assign proper jumpers.
See below.
So far so good...
Now, I don't see my jumper on my schematic.  So I right click on TERMINAL 100 and select TERMINALS > EDIT JUMPER.
I then select TERMINAL 100 again, and select "S" to show the jumper.  It shows the jumper... however, it doesn't maintain that graphic once I click away.
Now, others have suggested I simply show wiring to the terminals in a typical fashion, however, my reports see this as a wire and not a jumper bar (I assign part numbers to my jumper bars).
Is there a step I'm missing or perhaps I'm not toggling something correctly?
Let me know, thanks!
Lou Branchaud
Electrical Designer
3 REPLIES 3
rhesusminus
in reply to: LOUBRA
Unfortunately you'll have to draw the jumpers manually in the schematics, or maybe insert a jumper chart via the Terminal Strip Editor.
I do it like this, with donuts an polylines:
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
dougmcalexander
in reply to: LOUBRA
Create a wire type named JumperBar. Connect this wire type between terminals. A wire type with the word JUMPER in the name will be ignored from the wire from/to report. I insert graphical jumpers over my terminal strips after I insert the strips. These graphical jumper footprints are preloaded with the MFG and CAT data, so they can be ballooned, and so they appear in the BOM. I cover all of this at: www.ecadconsultant.com
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
LOUBRA
in reply to: dougmcalexander
Thanks for the help.
What I ended up doing is simply drawing a dashed line through any jumpered terminals and I assign the mfg / cat information in the Terminal Strip Editor.
I also had the jumper chart & terminal layout shown on seperate pages.  I just thought there was an easy way to automatically show the jumpers.
Cheers!
”Boost
