AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Sheet number not showing for "Reference only"-drawings in project manager
3 REPLIES 3
rhesusminus
1024 Views, 3 Replies
Hi.
When turning on the ability to show sheet numbers in the prosject manager (using Drawing List Display Configuration), the sheet number won't show when a drawing is set up to be for reference only.
The sheet HAS a value in the drawing in the sheet-field of the drawing properties. If I remove the "for reference only" check mark, the sheet number appears again...
This must be a bug?
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
3 REPLIES 3
It has been that way for a while. It does seem like a bug though. But the sheet numbers show up in reports. There are other small issues like this; like the Suffix Setup dialog not showing the first radio button as the default. It doesn't adversely affect any other functions so it is probably low in priority for a fix.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Yes, appears to be an issue. I went ahead and logged it into our tracking system.
Sorry for the inconvenience.
Pat Murnen
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
mathalekar
in reply to: rhesusminus
I can reproduce this issue and is confirmed at our end. We will take appropriate action. Thanks for reporting
”Boost
