Hi.
When turning on the ability to show sheet numbers in the prosject manager (using Drawing List Display Configuration), the sheet number won't show when a drawing is set up to be for reference only.
The sheet HAS a value in the drawing in the sheet-field of the drawing properties. If I remove the "for reference only" check mark, the sheet number appears again...
This must be a bug?
Solved by mathalekar. Go to Solution.
Solved by PatMurnen_Adsk. Go to Solution.
Solved by dougmcalexander. Go to Solution.
Yes, appears to be an issue. I went ahead and logged it into our tracking system.
Sorry for the inconvenience.
Pat Murnen
I can reproduce this issue and is confirmed at our end. We will take appropriate action. Thanks for reporting
