Good suggestion. I will log that as well. By the way, my logging it is no
guarantee that it will be implemented but we do consider all suggestions
like this that are logged.
Thanks again,
Pat Murnen
wrote in message news:5190460@discussion.autodesk.com...
Thank you for your reply.
The new feature in 2007 has helped. But, there are still times I had the
wrong table overwritten, because I picked the wrong set file at the start
and there is no quick way to know you are using the wrong set file.
I have one more suggestion for the Report Generator. It would be nice if we
could also pick an existing table to select the set file of that table,
report format settings and the table generation setup, which I believe is
stored as xdata on the table.
Thank You
