Martin,
What I suggested was to create 2 .set files and take the table options from
one and put in the other.
First, you are right you need one specific to Drawing List Report. The only
way to get that is to run the report, then from the Report Generator dialog
pick Change Report Format and make any necessary changes (or none) and pick
the OK+Save As button. Now you have a .set file for Drawing List report but
it doesn't have any Table Settings.
Now go into the Format File Wizard and pick any report. Go into the Put on
Drawing and set up the table options you will want for the Drawing List
Report. Save this in some other .set file name.
Now, using Notepad, open the 2nd .set file that has the Table= lines and
copy them from this file and put them at the end of the Drawing List .set
file created in step 1. Do not overwrite any of the lines that were already
in the Drawing List .set file. They are unique to that report.
Hopefully, this makes sense.
Pat Murnen
wrote in message news:5144348@discussion.autodesk.com...
Pat, nothing is working. When I use the wizard from another report (as in a
Terminal Report), the heading is different (Reprot = ) and when I change
that to be Drawing List, the Put on Drawing dialog box disappears instantly.
It looks like the Drawing list report ignors the Table = statements in the
SET file.
