Here are a couple of Pt100 symbols I use; one vertical and one horizontal. These are sized for the IEC2 library. The default RATING1 attribute value is Pt100 but this can be changed to fit your needs.
The main difference in this symbol and the built-in Variable Resistor 2 that ships with AcadE is the B for the default TAG1 attribute value, the removal of the arrow, and the addition of the qualifying symbol for RTD.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
