AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
scratch database and signal wire number question
2 REPLIES 2
m_simons
423 Views, 2 Replies
Hey,
I'm writing a utility that automates some usage of signals. I'm having an issue with wire numbers updating correctly on the destination portion of the signal. I can run a (c:ace_update_WFRM2ALL 1) to update the scratch database (and apparently it does some other things) then the destinations will update with the correct wire number.
It would be immensely better if the utility didn't have to run (c:ace_update_WFRM2ALL 1) every time a signal was processed. So what I did was open up the scratch database and try to shove my wire numbers in there manually. I notice wire numbers are in the following tables SIG, WNUM, WIRESEG, WNETLST. I open a file handle and push the wire numbers in via SQL statements. I can watch the correct information being populated, however when I go to the destination and update the signal after pushing the wire numbers in, ACADE still pulls old or ??? wire number values from...somewhere. Where does ACADE store this information? It would be extremely benificial to update this information one signal at a time instead of refreshing the entire database.
Any info would be hugely appreciated.
2 REPLIES 2
dougmcalexander
in reply to: m_simons
If you push the wire numbers into the database, you must immediately update the drawings from the database.  This is not a normal function for AcadE, since the database gets updates from the drawings.  But you can push data into the database and have it reflected in the drawings.  You just have to force an update of the drawings from the MDB using the command found on the Import/Export Data menu tab.  (see attached screen capture)
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
m_simons
I checked into updating from the MDB, it still isn't quite what I need.
I found a way around this updating problem, but the utility I wrote is now a giant cludge. (it goes through each drawing, and creates a list of souce/destinations that need to be updated, then it has to go BACK and update all the drawings after I run a (c:ace_update_WFRM2ALL 1)
How does ACADE "link" the source and destination information? I would like to force updates "real time" instead of running (c:ace_update_WFRM2ALL 1)
Thanks again.
”Boost
