I have a similar problem. I've tried deleting the database file, no change. I've narrowed it down to this:
schematic reports - bill of material utility only picks up items added as schematic symbols, ignores footprints
I tested this by creating a new project. I can add a schematic symbol, and the part shows up in the BOM, but if I add the footprint, it does not show up. This was working fine, and starting yesterday, it stopped working.
I using AutoCAD Electrical 2008 SP2.
Brian
Brian,
the Schematic Bill of Materials report only lists scheamtic symbols (with catalog information on them). There is a Panel Bill of Materials report that lists footprints. The Panel Bill of Material report has an option to list schematic components that are not represented on the panels. This is a FULL bill of materials report.
Hope this helps,
Pat
I only use a Schematic BOM for a design review prior to doing the panel layout. My final BOM always comes from the Panel Layout, so my BOM contains hardware items. In my classes I simulate a design review with the Schematic BOM, but on the final day we generate automatic reports, including a Panel BOM. If you choose Panel BOM and select only schematic pages to process there will be no data to display. If you select Panel BOM and select to process all drawings the program is smart enough to only display footprint data in the report.
Thanks guys, I didn't realize there were two separate utilities. In my frustration of trying to figure out why id 'didn't work' I can't remember all the details of how I was getting it done before.
Looks like it will do what I need, thanks for the guidance!
