AutoCAD Electrical Forum
Schematic BOM reports not displaying
6 REPLIES 6
325 Views, 6 Replies
Working on our first project 2006/JIC125 and I can't get user1 and description to show up on the BOM report. I put the information in the MDB file. the missing info is on a fuse block terminal that I created.
6 REPLIES 6
JeffatSJE
which table in the default_cat.mdb file? I do a catalog lookup on it and ACE wants to open a table called RM or RMS not TRMS
I don't know what I'm doing wrong, it is looking in (table: RMS.
I do a (Componet Edit) on my fuse terminal block and then do a (Catalog Lookup).
It looks in (Table:RMS).
If I select ("Other" reference another table) and look in (Table:TRMS), I can see my User1 and Description.
Any idea what I am doing wrong or need to do different?
JeffatSJE
Add a family code attribute and set its default to TERMS and re block it or create a new table called RMS
I created a table RMS - and the schematic reports still does not report user1 and description.
I do not know where to find the "family code attribute", I exploded a terminal symbol and could not find it.
Any more ideas?
JeffatSJE
I re-blocked your fuse terminal block see attached.
try it out. You should re create it your self I may not have picked a good insertion point.
Thanks - you saved the day - the fuse terminal block works now.
”Boost
