AutoCAD Electrical General Discussion
New Member
RobIAE
Message 1 of 2 (377 Views)
Schematic Blocks
377 Views, 1 Replies
06-16-2005 01:44 PM
I'm a newbie and just wanted to make sure I just didn't miss things when I installed AE. I was a little surprised by the fact that the schematic components in the Libs are limited to simple base components - CBs, fuses, relays, etc.
There is no library of power supplies, surge suppressors, etc? I assume I will be building these using the black box utility?
Also the "Insert PLC module" function is limited to I/O, correct? No CPU or communication modules?
I'm pretty sure I did a full install - just wanted to verify that there aren't some libraries out there that I missed.
Distinguished Contributor
MartinLee
Message 2 of 2 (377 Views)
Re: Schematic Blocks
06-17-2005 04:03 AM in reply to: RobIAE
As far as I know, you are correct on all three points. Depending upon which PLC you are using, you will have to make your own symbols. I've had to make symbols for my CPUs, Ehternet Cards, and in some cases, power supplies. These are not parametric build, just plain ACE symbols with wire connections if needed. The names start with PLCIO so that the catalog lookup dialog appears the same as the parametric build symbols.
Since I have my own custon symbol library, I don't keep up with what comes with the JIC or IEC set. It would be quite a task for Autodesk to include symbols for every electrical/electronic device available world-wide. Plus with new devices appearing almost everyday it would be an even bigger task to keep up with that. So we have to make our own from time to time.
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
