AutoCAD Electrical General Discussion
rta53
Message 1 of 5 (125 Views)
Scaling ABECAD components
125 Views, 4 Replies
03-25-2004 05:29 AM
I have successfully inserted panel components such as pilot lights and push buttons on my front panel layout without any problem. I actually use the enclosure drawing from Hoffman and everything is scaled properly. However when I try to insert components onto the back panel using ABECAD they are scaled much too large. How do I fix this?
testsubject
Message 2 of 5 (125 Views)
Re: Scaling ABECAD components
03-25-2004 07:11 AM in reply to: rta53
You need to rescale those parts. They were probably drawn in metric. Save them to your hard drive and rescale to Standard (ft,in)
Bob Hanrahan
Ace User since 1998
rta53
Message 3 of 5 (125 Views)
03-25-2004 05:27 PM in reply to: rta53
The blocks are in metric. How do I rescale?
rta53
Message 4 of 5 (125 Views)
03-26-2004 04:20 AM in reply to: rta53
ok, I figured out one way to do this. I use the scale command and type a reference number and then a scale number. For example, when I bring in a 6 mm terminal block I use 6 as the reference number and then .236 as the scale number which is the decimal inch equivalent of 6 mm. Is there a better way of doing this?
testsubject
Message 5 of 5 (125 Views)
03-26-2004 06:08 AM in reply to: rta53
That is the only way I know how to scale a part. I would suggest that you do the original .dwg so that you do not have to scale it every time you use that part. I usually use 25.4:1 for my scaling. 25.4 mm=1 inch.
Bob Hanrahan
Ace User since 1998
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
