AutoCAD Electrical General Discussion
Dan.M
Message 1 of 5 (858 Views)
scale components after insert
858 Views, 4 Replies
12-17-2012 02:13 AM
How can I scale up only the electrical blocks in the scheme.
They came out a little bit small. i work with Eletrical 2013
Dan
Sware/Update block - Option B - Update a block - Choose scale. Is this you are looking for?
Nata_ly
Message 2 of 5 (849 Views)
Re: scale components after insert
12-17-2012 05:14 AM in reply to: Dan.M
Dan.M
Message 3 of 5 (835 Views)
Thank you.  Dan
12-17-2012 11:16 AM in reply to: Nata_ly
Thank you.
Dan
Valued Contributor
jdonaldson3
Message 4 of 5 (830 Views)
12-17-2012 12:02 PM in reply to: Nata_ly
I want to make a small comment on your answer. Where the command is, or what it actually is would be helpful for those of us new to Electrical. I had to use the help command to find the following:
Ribbon:  Schematic tab  Edit Components panel  Swap/Update Block.
Toolbar: Insert Component
Menu:  Components  Component Miscellaneous  Swap/Update Block
Command entry:  AESWAPBLOCK
Just an FYI
Icemanau
Message 5 of 5 (822 Views)
12-17-2012 02:31 PM in reply to: jdonaldson3
Try swapping your block library. From the looks of the screen capture, you are using a smaller library than required for the sheet size.
For example, you might be using IEC2 when for the sheet size, you may need to be using IEC4. The only differrence between the two libraries is the scale of the inserted blocks.
To swap a library, go to the Swap/Update block tool and in section 'B' choose the second option. Choose the appropriate library and let the tool run.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
