How can I scale up only the electrical blocks in the scheme.
They came out a little bit small. i work with Eletrical 2013
Dan
Solved by Nata_ly. Go to Solution.
Sware/Update block - Option B - Update a block - Choose scale. Is this you are looking for?
I want to make a small comment on your answer. Where the command is, or what it actually is would be helpful for those of us new to Electrical. I had to use the help command to find the following:
Try swapping your block library. From the looks of the screen capture, you are using a smaller library than required for the sheet size.
For example, you might be using IEC2 when for the sheet size, you may need to be using IEC4. The only differrence between the two libraries is the scale of the inserted blocks.
To swap a library, go to the Swap/Update block tool and in section 'B' choose the second option. Choose the appropriate library and let the tool run.
Regards Brad
Brad Coleman, Electrical Draftsman
