Tom,
What you can do is delete the user circuit .dwg files that you no longer
need. The next time you run this command they should no longer show in the
list of existing circuits. By default these are saved in your User folder as
CIRC##.DWG. The default location of the User folder is "C:/Documents and
Settings/{username}/Application Data/Autodesk/AutoCAD Electrical
2006/R16.2/enu/Support/user/". If they aren't there you may have an
alternate folder defined for these with a line in your wd.env file pointing
"WD_USERCKTDIR" to some other folder.
I believe this was a reported issue and was corrected in AcadE 2007.
Hope this helps,
Pat Murnen
wrote in message news:5510803@discussion.autodesk.com...
Pat,
I am experiencing the exact error which was described in
5179078@discussion.autodesk.com.
I am running AutoCAD Electrical 2006 SP2a Version Z.77.0.
I have no difficulty in creating new circuits.
When I try to redefine an existing circuit, it asks if I want to overwrite.
When I click yes, the command drops out and the "Error: bad argument type:
stringp nil" pops up.
Is there a way to manually delete the link to the existing circuit
definition so that I use a circuit "as new"? What file would need to be
edited? I am running out of circuits.
Tom
