AutoCAD Electrical Forum
Right-Click won't work.
5 REPLIES 5
868 Views, 5 Replies
For no apparent reason that I know of, my right click function stopped working. I can't "enter" a command or get shortcuts or anything else. I went into Tools > Options > User Pref > Right Click and everything looked like it should be. Any suggestions?
5 REPLIES 5
It could be a mechanical failure on the part of the mouse. Have you tried
another mouse? Does right click work on the windows desktop?
Regards Brad
wrote in message news:5798721@discussion.autodesk.com...
I am also facing the same problem. Can anybody help to fix the problem.
Shaffy
Its not a hardware problem. It works fine with all other applications. Have you found a solution Shaffy?
Yes, i found the solution for it. I created new user profile in windows and then it worked fine.
Shaffy
I was just logging on to tell you the exact same. Kind of strange how is tied to the problem, but i'm glad its fixed.
”Boost
