Kevin,
I think I see what you are seeing now. If your crosshairs are over an
AutoCAD Electrical object, like a symbol or a wire, at the time you hit the
right-click you will get the Electrical shortcut menu. When the right-click
it hit, it looks to see what is under the crosshairs, and if it is an
Electrical object(symbol, wire, wire number, etc) the shortcut menu will
appear.
When you hit the right-click just place the crosshairs in a blank area of
the drawing and see if this solves the issue.
Steve
wrote in message news:4877208@discussion.autodesk.com...
I checked my Right Click customizations and they are set as per your jpg
file.
This issue is infrequent, I can work in AutoCAD for several minutes with no
problems and then it will just start happening. I might be editing a line,
editing text, drawing lines or moving objects. I can't find a common
denominator for it. I use the shortcut commands almost entirely, for
example, I enter a Z for zoom, right click the mouse to Enter the command
and then enter a W for window and right click again. Some of the time it
works ok, most of the time I get the Electrical Shortcut menu instead of
performing the Enter function.
I tried hitting the Enter key and it does close the Electrical Shortcut
menu, but then I have to hit the Enter key again to get the command to input
into AutoCAD.
This is very frustrating, am about ready to turn ACAD 2006 off and go back
to 2000 until a fix is found.
