AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Right click context menu problem
7 REPLIES 7
Message 1 of 8
1860 Views, 7 Replies
increasingly, whenever I use the right click context menu to perform electrical tasks such as edit component or scoot or surf etc I find the plain AutoCAD right click menu popping up instead. An additional right click will usually bring up the electrical menu but this is annoying. Can anyone give any clues as to why this is happening and why it seems to have started recently?
MR
7 REPLIES 7
Message 2 of 8
vladop
I asked the same question in
http://discussion.autodesk.com/adskcsp/thread.jspa?threadID=668136
but get no answer.
Message 3 of 8
Except in my case the plain AutoCAD right click menu appears before I am able to take any action, whereas in your case you take the action and then the AutoCAD menu gets in the way.
Can an AutoDesk person give us a clue as to what is happening here - is it us or you?
MR
Message 4 of 8
dougmcalexander
There were some issues in earlier releases where the regular Acad context
menu would appear the first time you tried to edit something after starting
AcadE. But this happens rarely anymore, as long as you are clearly over an
electrical component or a wire. Be sure when you right click that your
cursor is over an electrical entity. This is what triggers whether or not
you are editing a component, a wire, etc. and brings up the appropriate
right-click options. If your cursor is not over an electrical entity you
will get the standard Acad context menu.
wrote in message news:5976966@discussion.autodesk.com...
us or you?
MR
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Message 5 of 8
vladop
I have a problem with right click context menu (OS XP). It doesn't show electrical commands.
This line from c:\program files\autodesk\acade 20xx\acade\wd_load.lsp:
(vlr-mouse-Reactor nil '((:vlr-beginRightClick . wd_checkRClick)))
solves the problem.
How can I make this reactor permanent.
I tried with acad.lsp and wd.env.
Regard,
Vladimir
Message 6 of 8
I realize that this is an old tread but I was having the same issue.
My issue started mid day for no apperent reason
By typing in the command line
the right click edit component started working again
I have that line in the wd_load.lsp the LSP routine loads but the command line doesnt seem to work
I put that line into my ACAD.lsp and the issue was solved
anyone know why it wouldn't work in the WD_LOAD.LSP but it works in the ACAD.LSP
Both files are loaded through the startup suite.
Dennis
Message 7 of 8
in reply to: dougmcalexander
Either you aren't aware of how much this happens or you are straight up misleading us.  now I agree that it wasn't that bad in AE2017 and earlier but in AE2019 it is just ridiculous. This right click issue is physically happening every single time I right click on AYTHING. it doesn't matter if its a component, wire, wire #.. it doesn't matter what I select or how I select it. I can grip the component, wire or whatever and the Acad quick menu shows every single time and have to cancel it to get the component dialogue box to appear. Is there a fix to this or do I have to just start thinking about abandoning this program? Because after using this program since AE2012 it seems like it is going backwards on the programming side.
thanks
Message 8 of 8
Icemanau
First of all, the post you replied to is about 6 years old and likely hasn't been read in over 5 years apart from the occasional search. It would have been better to post this in a new message as there is a world of difference between the different releases.
Now some questions to try and pin down the cause of your problem.
In the ACAD Options on the User Preferences tab, what are the Right Click Customisations set to?
If the Time Sensitive Right Click is enabled, have you tried increasing the time before the shortcut menu comes up?
Have you tried entering AEONRIGHTCLICKCONTEXTMENU on the command line? This should turn the Marking Menu on.
What is the setting for the AEMM option as this could also be causing problems? Three should be the default here...
NOTE,- both of these commands are dwg based rathe than program based. That means that while they will work on one dwg, they will not work on all dwgs and will need to be set on each dwg. I suggest setting them on your template dwg so that any new dwgs going forward have these set correctly.
Regards Brad
Brad Coleman, Electrical Draftsman
”Boost
