I have a problem with right click context menu (OS XP). It doesn't show electrical commands.
This line from c:\program files\autodesk\acade 20xx\acade\wd_load.lsp:
(vlr-mouse-Reactor nil '((:vlr-beginRightClick . wd_checkRClick)))
solves the problem.
How can I make this reactor permanent.
I tried with acad.lsp and wd.env.
Regard,
Vladimir
I realize that this is an old tread but I was having the same issue.
My issue started mid day for no apperent reason
By typing in the command line
the right click edit component started working again
I have that line in the wd_load.lsp the LSP routine loads but the command line doesnt seem to work
I put that line into my ACAD.lsp and the issue was solved
anyone know why it wouldn't work in the WD_LOAD.LSP but it works in the ACAD.LSP
Both files are loaded through the startup suite.
Dennis
Either you aren't aware of how much this happens or you are straight up misleading us. now I agree that it wasn't that bad in AE2017 and earlier but in AE2019 it is just ridiculous. This right click issue is physically happening every single time I right click on AYTHING. it doesn't matter if its a component, wire, wire #.. it doesn't matter what I select or how I select it. I can grip the component, wire or whatever and the Acad quick menu shows every single time and have to cancel it to get the component dialogue box to appear. Is there a fix to this or do I have to just start thinking about abandoning this program? Because after using this program since AE2012 it seems like it is going backwards on the programming side.
thanks
First of all, the post you replied to is about 6 years old and likely hasn't been read in over 5 years apart from the occasional search. It would have been better to post this in a new message as there is a world of difference between the different releases.
Now some questions to try and pin down the cause of your problem.
In the ACAD Options on the User Preferences tab, what are the Right Click Customisations set to?
If the Time Sensitive Right Click is enabled, have you tried increasing the time before the shortcut menu comes up?
Have you tried entering AEONRIGHTCLICKCONTEXTMENU on the command line? This should turn the Marking Menu on.
What is the setting for the AEMM option as this could also be causing problems? Three should be the default here...
NOTE,- both of these commands are dwg based rathe than program based. That means that while they will work on one dwg, they will not work on all dwgs and will need to be set on each dwg. I suggest setting them on your template dwg so that any new dwgs going forward have these set correctly.
Regards Brad
Brad Coleman, Electrical Draftsman
