The project has two coil reversing relay.
The report says the two products, although the reversing relay - this is one product that contains two coils. You have to manually change the data report.
What you need to do to make the report includes only one product - a reversing relay?
You should only assign MFG and CAT data to one coil. I have attached an example schematic and BOM.
Another approach would be to have the second coil be a child component and make it a type 4 contact. (Probably something like 4X or 4CL for the contact attribute.)
