Is there a way to search for all Rev Clouds in a Project? For example a project may have 100 pages of dwgs and a command that runs through all the dwgs and searches for rev clouds would be helpful.
it can be done but probalbly not in your current project
if you have used the revcloud command then you have created a polyline
now what i do is i have a layer called "info" colour magenta and the layer is set not to print
i put text notes and revclouds on this layer that does not print when i generate a PDF etc
if you go to here
i talk about the data extraction wizard
i can cofigure this to produce a list of polylines on layer "info" with a page referance(which can only be a revcloud in my setup)
you can try to use this in your current setup it might point you to the right pages but what i would do at this late date is just pdf the page and use the acrobat mark up tools to quickly stamp the pages with a revcloud you can then jump to these pages in the pdf and use this as a quick referance guide
Another option, which can be surfed with Electrical Surf, is to insert Stand-alone Crossreference sources on an index page and insert matching destinations throughout the project where the revisions are located. You can surf to and from the revisions by surfing the Stand-alone Crossreferences. See attached example.
Hi Glocked1,
You could try using the DWF's, then clients or other people from your company can markup the Drawings as they see fit, and use the markup manger built into AutoCAD to overlay the DWF's requirements (The Rev Clouds, notes, Doodles that you want to convey). You can Bring up the Markup Sheet manger with "CTRL + 7".
It won't help you with this project unfortunately, but it could help you in the future.
As the DWF manager lists all marks on the drawing letting you pick and choose what you want to do in the order you want (or Send Questions back for Clarification on a copy of the DWF). its a nice way to keep track of pending changes, completed changes, and changes you have rejected.
I hope this helps,
James Alger
One other thing you could use:
Mark/Verify Drawings (This is an ACADE Command)
Mark sets a point and records all changes made to the drawing from that point.
Verify lets you Review all the changes that were made (It can capture regular AutoCAD Commands, deletes, etc) you can surf to the changes after that,
I hope this helps,
James Alger
Thanks, but I was thinking more along the lines of using VBA to somehow find them. Problem is I am not much of a coder so would need the code and then paste it in the module within VBAIDE.
