AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Retag Components Electrical 2009
1 REPLY 1
cbasulto
209 Views, 1 Reply
In a Drawing with a PLC Output Card I have a CB and a SOL, the attributes for my Component are
%F%X-%N
When I use the "Project-Wide Update or Retag" option and check the Component Retag box it names the component SOL-12, where "12" is the Line Number.
On the same Drawing if I use the menu, Components-Component Tagging-Retag Components, it changes the name of the Solenoid to
SOL-O:5/3
The address for the CB on both cases is CB-O:5/3
The Component properties are the same for my Project and my Drawing and I have the "Search for PLC I/O address on insert" box checked
How can I make that the Project Wide Retag option leave the name of the Solenoid with the PLC address instead of the line number?
I tried this on ACAD Electrical 2008 and 2009 and I got the same results.
Carlos
1 REPLY 1
in reply to: cbasulto
I wasn't able to reproduce this for AcadE 2009. Can
you post a sample project and drawing to try this on? Or you can email directly
to me at
href="mailto:pat.murnen@autodesk.com">pat.murnen@autodesk.com
Pat Murnen
In
Component are %F%X-%N When I use the "Project-Wide Update or Retag" option and
Line Number. On the same Drawing if I use the menu, Components-Component
Tagging-Retag Components, it changes the name of the Solenoid to SOL-O:5/3 The
address for the CB on both cases is CB-O:5/3 The Component properties are the
on insert" box checked How can I make that the Project Wide Retag option leave
the name of the Solenoid with the PLC address instead of the line number? I
Thanks, Carlos
”Boost
