Several designers use a common database default_cat.mdb, stored on the server.
One designer adds new items to the database, and the rest just select the desired catalog data.
How in AutoCAD Electrical restrict access only to select, without the right to make changes to the database?
That is, the “Edits catalog database” button should not be active.
Solved by rhesusminus. Go to Solution.
The access to this file on the server is controlled by setting NTFS rights to the file.
So, one user can have "full access" while the others have "read only".
