AutoCAD Electrical General Discussion
Active Contributor
mgoolsby75
Message 1 of 4 (158 Views)
Accepted Solution
resizing component term# text size
158 Views, 3 Replies
10-07-2011 08:14 AM
I would like to know how to set my component term and pin numbers outside of the component instead of it placing the numbers inside of the contact. I will include a DWG so that I can better show you what I am talking about. I woould like to set this as a default upon insertion. Any help would be greatly apprciated!!!
Thank you,
Michael Goolsby
*Expert Elite*
testsubject
Message 2 of 4 (152 Views)
Re: resizing component term# text size
10-07-2011 10:08 AM in reply to: mgoolsby75
I would just modify the original drawings used for those blocks and then do a Swap/Update Block. Normally, I make a copy of the original first and then use that to do the modification. Whenever you update ACE, it always replaces the existing as designed blocks with new ones from the new installation and this would write over your changes.
Bob Hanrahan
Ace User since 1998
*Expert Elite*
rhesusminus
Message 3 of 4 (139 Views)
10-08-2011 01:32 AM in reply to: mgoolsby75
You should save all changes you do to a separate symbol library. Then.. just make sure that your Symbol Library is added to the schematic symbol library search list... as the first item.
Now, AcadE will find your version of this symbol first, no matter what version of AutoCAD Electrical you are running in the future.
THL
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
*Expert Elite*
testsubject
Message 4 of 4 (137 Views)
10-08-2011 03:20 AM in reply to: rhesusminus
I should have said that also. I do that now.
Bob Hanrahan
Ace User since 1998
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
