AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Resize wireway on panel drawing after inserted
10 REPLIES 10
Message 1 of 11
1577 Views, 10 Replies
How do you resize wireway or din rail after it is inserted in Autocad Electrical 2013?
thanks
Jason
10 REPLIES 10
Message 2 of 11
Jason,
I believe you have to delete the wireway / DIN rail and insert it again.
Message 3 of 11
stefan.stamate
You can also create your own dynamic block for a wire duct and DIN rail which will give you the option to adjust the length or even pick up a different size.
Message 4 of 11
in reply to: stefan.stamate
Good idea Stefan,
I had not considered a Dynamic Block.
Unfortunately, the existing DIN Rail / Duct insert tool does not allow for use of Dynamic Blocks.  The tool generates blocks parametrically, but the resultant block does not have embedded dimension parameters.  The user would have to stop using the DIN Rail Insert utility and generate their own set of blocks.
This would be a good feature update for AutoCAD Electrical's team to run with.
Message 5 of 11
stefan.stamate
Yes, you will have to create your own and add a new link/symbol to the Panel Symbols menu using the "Icon Menu Wizard". Take a look at the attached file for a dynamic bloc for adjustable DIN rail.
Message 6 of 11
Great work Stefan,
Thanks for the demo drawing!  I'll take a look at this.
Message 7 of 11
stefan.stamate
When you open the drawing you will get a message that it contains extra features and if you want to open it in the Block Editor. Choose yes and you will see the attributes.
Message 8 of 11
drathak
I don't have a lot of experience with that utilty, but could you find the pieces that is built from and add the dynamic attributes in those?
Also, I have tried to make some dynamic symbols for the schematic but once you stretch them they pick up an alternate ID or something that keeps them from being found by ACADE sometimes.  (I'd have to hunt up my notes to remember exactly what happened.)
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
Message 9 of 11
stefan.stamate
in reply to: drathak
Hi Joe,
If you insert the DIN rail drawing I have provided as a block into your drawing it will give you the option to adjust its length to a maximum of 1m. The dynamic adjustment is already in there.
Cheers,
Stefan
Message 10 of 11
dougmcalexander
Actually, you can use the Stretch PLC utility to resize any block after it is inserted. This utility was called Stretch Block in earlier versions. You can find it on the Schematic menu tab under the Scoot drop-down arrow. I used CUI to rename mine back to Stretch Block and I also duplicated it on my Edit Footprints menu panel for convenience.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Message 11 of 11
drathak
in reply to: dougmcalexander
Bloody Hell....
Been wanting exactly that forever!!!
Thanks Doug!
Joe Weaver
”Boost
