<Sometimes
href="mailto:srobinson@gcontrol.net">srobinson@gcontrol.net> wrote in
message
href="news:6073943@discussion.autodesk.com">news:6073943@discussion.autodesk.com...
when I resequence the item numbers in my panel layouts, the terminals get
thrown out of whack. They get offset in a seemingly random manner, not much,
but enough that the entire terminal strip has to be reinserted. I do not know
if this is because all the terminals we insert are our own blocks or not
because we never use the generic blank blocks that come out of the box with
autocad. Is there something wrong with my blocks that could cause this? I am
on ACADE 2009 SP2.
<Mauro,
message
href="news:6078298@discussion.autodesk.com">news:6078298@discussion.autodesk.com...
1- This is the PITEM, which I think is what is populated when a "resequence
item number" is done. 2- Not sure what you mean by what tool? 3- Yes, or the
new work around is to zoom into an area that doesnt show any
terminals.
<sgsawdy> wrote in messageWe
href="news:6078104@discussion.autodesk.com">news:6078104@discussion.autodesk.com...
are still using 2008 sp2 and we wind up losing our Item numbers altogether.
Whenever I use the TSE to insert terminals, all of those inserted terminals
have to be manually given an item number. They will not allow automatic
assignment or re-assignment. This is a real pain, but, I wrote a command
p_item to let me select multiple blocks and assign the item number as xdata.
This works well enough to get us by, although some types of blocks seem to
require the item number be an attribute. Then I have to use a different
utililty that lets me edit the values of up to three existing attributes to a
selected group of blocks. Still not perfect, but it lets us get our work done.
Scott
I still would like to know what is causing some of my footprint blocks to move. It's not just terminals and many blocks never move after resequence. Also I don't understand the "add p_item" attribute.
The add P_ITEM attribute probably means that one or more of you footprints does not have that attribute in it.
You will need to check the blocks and add the attribute to the blocks that are missing it.
Regards Brad
Brad Coleman, Electrical Draftsman
