Nate,
i have followed your instructions as per below, however the *.set file is not holding the column width info, neither is there a line in the set file that i can edit to force them.
i have created a file called "bom_fra.set" in my user folder. in the ASCII file there are lines as follows:
reportname - as per above
format - indicates the column headers used (and in which order)
title - names of all possible column headers
characters - im assuming this is the max characters in each column row
justification
sorting
can i enter my own line to force column widths? i notice the above post was some time ago, is this something that has been changed in acade 2006? if so, how can i do it now.
also, the first column of my reports is the item column. why does this always appear blank? i want it to just read 1, 2, 3 etc.
