It seems that maybe there is confusion between remove and delete. Removed a
drawing from the project does not erase the drawing file from the project
folder. There should be no need to compare anything. Just right-click the
drawing and remove it from the project. If you want it deleted from the
hard drive, then open the project folder containing the drawings and delete
it.
wrote in message news:5995688@discussion.autodesk.com...
Hi there,
I removed some drw through right click in the project manager but i noticed
that these drw still exist in the project file.
is there a way to delete them all without comparing one by one the project
file and the drw in the project manager?
thnx
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
