Steve,
I'm not sure I completely understand what you're seeing or not seeing but
I'll give it a shot and you can tell me if this does or doesn't work. Open
up your dwg#1 in AutoCAD Electrical and pick on the "Drawing Configuration"
toolbar button (next to last button on the main AcadE toolbar). Make sure
you have your drawing "sheet" number value of "1" entered into the edit box
along the right-hand edge of the configuration dialog. Then hit the "Setup
cross-ref" button at the bottom center part of this dialog. Make sure that
your cross-ref format in both boxes carries a value of "%S%N" so that your
sheet number gets appended to your line reference 1-50 number... so, on
sheet 1 references will be 1xx where xx=1-50, sheet 2 will be 2xx, and so
on. If it seems that I'm not understanding the problem, please reply.
thanks,
Nate.
"Duck" wrote in message
news:4057508b_2@newsprd01...
> To all,
> I am using sheet numbers with my reference numbers in ladder drawings.
> I am having trouble getting all of my drawings to update ladder sequence
> correctly.
> The title blocks all reflect the correct data, but the ladder get all
messed
> up.
> For instance> dwg #1 ref numbers 1-25,26-50
> this drawing may show ref numbers as 2 digit ref
> only with no sheet number
> > dwg#3 ref numbers 1-25,26-50
> this drawing may show ref numbers correctly
> 301,302,303,304,etc...
> All drawing are configured the same and all check against the project
> database correctly.
> I know I am probably doing something wrong but am out of ideas.
> Am also very new to AutoCadd Electrical
> Thanks in advance for your patience and help
> Steve Duckworth
