You could do that but the easy way is to use a wd_fam.dat file. I will attach mine. I have to rename it to wd_fam.txt in order to attach it. Rename it to wd_fam.dat and place in your project folder or user folder. You can modify to suit your needs. It is a simple text file created with Notepad but saved with a .dat extension. The syntax is ORIGINALfamilycommaNEWfamily. For example when I place down a relay coil, I want K instead of a CR. I type into the first line of the wd_fam.dat file CR,K. To have a lamp be H instead of LT my second line would be LT,K. To convert FU to F for a fuse enter FU,F. And so forth for each component type. I have been doing this for years since I do drawing conversions from JIC to IEC. When you place symbols into the schematic from now on, they will automatically get retagged based upon the wd_fam.dat file. For a existing project, do a project-wide retag. If you need to temporarily suspend this retag function, temporarily rename the wd_fam.dat to wd_fam.txt or your initials.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
