All you need to do is create a new project using the New Project button. Move the drawings into the folder that gets created for this new project. Right-click on the new project in the Project Manager window and select Add Drawings. Add the drawings to the new project. Furthermore, you can use the Settings Compare utility to force the new project to assume the settings of one of the drawings.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
