AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
re assigning components
4 REPLIES 4
202 Views, 4 Replies
Hi Can anyone tell me if its possible to reassign a schematic component to become a One Line Component. I don't seem to be able to see or edit the WDTYPE attribute after its inserted..
4 REPLIES 4
It may be hidden Xdata. You can use the Xdata editor provided to add or
change this. If it is Xdata then it needs to have the previx VIA_WD_. The
Xdata editor is in the Project tab, Other Tools expanded panel.
Pat Murnen
wrote in message news:6302530@discussion.autodesk.com...
Some schematic symbols do not have the WD_Type attribute included with them. You can also use the Swap/Update Block command to exchange the existing schematic symbol with the equivalent One-line symbol that does contain the attribute.
Yes, and actually I was mistaken about the xdata. I don't think WDTYPE can
be xdata. I believe it is only supported as an attribute. Sorry about any
confusion I may have caused. Any component without a WDTYPE attribute is
identified by the usual method, that is if it has a TAG1, TAG2, TAG, etc.
attribute. One-line components can carry the same attributes as any
schematic symbol so they needed something further to identify them.
Pat Murnen
wrote in message news:6302921@discussion.autodesk.com...
attribute.
Yes.. i saw another thread this afternoon re one line diagrams that led me to the swap update block command and it does the job perfectly... of course now I know on future projects I will define one line components properly in the first place @! and avoid the need to change them.....
this is such a good forum for needy beginners like me!
thanks all
”Boost
