Yes, and actually I was mistaken about the xdata. I don't think WDTYPE can
be xdata. I believe it is only supported as an attribute. Sorry about any
confusion I may have caused. Any component without a WDTYPE attribute is
identified by the usual method, that is if it has a TAG1, TAG2, TAG, etc.
attribute. One-line components can carry the same attributes as any
schematic symbol so they needed something further to identify them.
Pat Murnen
wrote in message news:6302921@discussion.autodesk.com...
Some schematic symbols do not have the WD_Type attribute included with them.
You can also use the Swap/Update Block command to exchange the existing
schematic symbol with the equivalent One-line symbol that does contain the
attribute.
