Using Phoenix rail mounted multi way terminals which can results in many terminal ways for each tag. OK until you report the terminal quantities then each terminal is reported not each block. Need a way to make a multi way terminal block a 'parent' item with the respective number of available ways as the siblings. i.e One block with 6 ways reports 6 terminals which is not true. 6 ways requires one terminal! If anyone knows how to force a parent any chance of advice. Al.
