style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Lint" <Also,
href="mailto:toland@gtequipment.com">toland@gtequipment.com> wrote in
message
href="news:f1a33c5.0@WebX.maYIadrTaRb">news:f1a33c5.0@WebX.maYIadrTaRb...
the wire selection does not carry over
the loops.
"Jared Bunch (Autodesk, Inc)" <
href="mailto:discussion.support@autodesk.com">discussion.support@autodesk.com>
wrote in message
href="news:FBB5DFF36AD05870295D81F7DD83FEFF@in.WebX.maYIadrTaRb">news:FBB5DFF36AD05870295D81F7DD8......
Lint
Are you using Electricals'
WIRE LAY utility or just using general AutoCAD commands to modify the
layer? If you use the WIRE LAY utility, it will change the layer of the
entire "wire" and not just the one selected line segment. Also, using
this utility will force the wire color/gauge labels to update. This
command can be found on the pull down menus' at:
ELECTRICAL > WIRING MISC > WIRE
LAYERS
I hope this
helps!
Sincerely,
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"Lint" <Also,
message
the
loops.
"Lint" <Yes,
message
href="news:f1a33c5.3@WebX.maYIadrTaRb">news:f1a33c5.3@WebX.maYIadrTaRb...
that helps! thanks.
Is there a central place where I can set the
test
height and move the label a set distance off the wire?
It seem like I have
to reset this on each drawing.
Lynne
