Mike,
Are you trying to edit the component by right-clicking on it and then
selecting the 'Edit Component' from the shortcut menu?
Also, do you know if you have 'Time-sensitive right-click' turned on in your
Options dialog?
One thing that might help me track this down is turn on the Command trace
option, Pull-down menu 'Projects->Extras->Command Trace Mode->Command Trace
On', and then right-click on a component and select the 'Edit Component'
option. Then hit the F2 key, do a right-click in the window and select
'Copy History' then paste all the history in a post up here so that I can
see when commands are running and were exactly it is failing.
Steve
wrote in message news:4830450@discussion.autodesk.com...
OK, my previous posts were mere annoyances, but this one is a killer. I have
tried editing both previously placed components and newly placed components.
NEITHER gives me the edit dialog for catalog data, descriptions, pin number,
etc. When I try to click on the object I get a "no previous view saved"
message. I use a marble mouse (tracball) and have had an issue with the
"right click" function being re-called after a click, meaning I have to hit
"enter" or "esc" after a right-click selection to perform the function i
selected. Are these related? I would suspect my marble, but the only program
it has issues with is ACADE.
Mike
