AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
"Fatal error: Unable to create client tray sink object"
13 REPLIES 13
Message 1 of 14
1043 Views, 13 Replies
Hi, i did a demo install on a new pc in the office, and i get this when i startup ACE. The i get "unable to communicate with the project database service".
Any clues please?
Thanks.
Regards.
Alex.
13 REPLIES 13
Message 2 of 14
This is a transcript of what i get when ace starts.
Hope it helps.
Regards.
Alex.
Customization file loaded successfully. Customization Group: ACADE
Customization file loaded successfully. Customization Group: ELECTRICAL
Customization file loaded successfully. Customization Group: EXPRESS
Regenerating model.
Loading Electrical modules.....
Failed to register AcePmDefun.
Unable to load the following modules:
C:\Archivos de programa\Autodesk\Acade 2006\AcePmClientApp.arx
Loader application completed
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD Electrical menu utilities loaded.
AutoCAD menu utilities loaded.
Command: COMMANDLINE
Message 3 of 14
Same here!
Message 4 of 14
Anyone home?
Message 5 of 14
HI
I got the same error whle istalling ACE2006 trial version on Win2000. This is 'coz if there is no ODBC installed u can not communicate to database. means ACE will not write to scratch databse. please look into your ODBC settings.
hope this will help u
regards
sathya
Message 6 of 14
I get this message when I installed the ACE 2007 software on my tablet PC. I am not familiar with the ODBC settings. Where do I find them and what should they be?
Message 7 of 14
Hi
go to administrative tools from control Panel.. there check out the driver Tab for Micosoft Access .. If not found.. please check user DSN tab there u can add the drivers u want..
hope this helps u
Request.. We are providing service in AutoCAD electrical Drafting and desigining.. If u want information about us please visit www. or www.engineering-link.com or www.control-infotech.com
Best regards
satya.nk@control-infotech.com
Message 8 of 14
Here are some other steps that you might try to correct this issue. If you
are already logged on to the system with Administrator rights, this might
not solve the problem.
- Log on as Administrator (Maybe if you just have administrator
rights might also work)
- Run Acade
- Log off Administrator and then log back on as the normal user
- Run Acade and see if this updates the registry and corrects
the problem.
This would correct an issue with certain registry entries being incorrect.
When Acade gets ran there are some registry entries that it needs for the
AcePmClientApp ARX file (this is an ARX file that is failing to load when
this issue occurs). If you are logged on as administrator you will have
full rights for the Acade program to correct what registry entries it can
and this might solve the problem.
Steve
wrote in message news:5165561@discussion.autodesk.com...
Same here!
Message 9 of 14
treellama
What should the ODBC settings look like?
Message 10 of 14
Has there been a fix for this problem? I too have the same error.
Message 11 of 14
sgilmo
I'm having the same problem, no joy here! Any better ideas?
Message 12 of 14
It can be solved if you know how to modify the registry.
These steps deal with manually modifying the registry and are NOT recommended for just any user to try. These steps should be carried out by an IT person or someone that has had a lot of experience with modifying the registry. If incorrect keys in the registry are modified or removed, it could cause the complete system to fail to boot.
1)Make sure you are logged in as administrator
2)If AutoCAD Electrical is running, close it
3)From the Windows Start menu select ‘Run’
4)Type in ‘Regedit’ and press ‘OK’
5)Expand ‘HKEY_CLASSES_ROOT’
6)In the expanded list, look for: ‘AcePmClientApp.AcePmTraySink.4’ and highlight it
7)Verify this is the correct key by looking in the status line at the bottom of the regedit window, it should read:
'My computer\HKEY_CLASSES_ROOT\AcePmClientApp.AcePmTraySink.4'
8)With this key highlighted, right-click on the key and select ‘Permissions…’
9)In the ‘Permissions for AcePmClientApp.AcePmTraySink.4’ dialog, highlight the ‘Administrators’ group in the ‘Group or user names’ section.
10)In the ‘Permissions for Administrators’ section, toggle the ‘Allow’ option for ‘Full Control’
11)Press ‘OK’
12)Exit Regedit and run Acade
Message 13 of 14
Thank you! That worked!
Message 14 of 14
There is also an AutoCAD Electrical knowledge base article for this issue
at:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=7343143&linkID=4199150
If you are unable to get there from this link, just go to the Autodesk
support page and search the Knowledge base for the word: sink
Steve
Same here!
”Boost
