It can be solved if you know how to modify the registry.
These steps deal with manually modifying the registry and are NOT recommended for just any user to try. These steps should be carried out by an IT person or someone that has had a lot of experience with modifying the registry. If incorrect keys in the registry are modified or removed, it could cause the complete system to fail to boot.
1)Make sure you are logged in as administrator
2)If AutoCAD Electrical is running, close it
3)From the Windows Start menu select ‘Run’
4)Type in ‘Regedit’ and press ‘OK’
5)Expand ‘HKEY_CLASSES_ROOT’
6)In the expanded list, look for: ‘AcePmClientApp.AcePmTraySink.4’ and highlight it
7)Verify this is the correct key by looking in the status line at the bottom of the regedit window, it should read:
'My computer\HKEY_CLASSES_ROOT\AcePmClientApp.AcePmTraySink.4'
8)With this key highlighted, right-click on the key and select ‘Permissions…’
9)In the ‘Permissions for AcePmClientApp.AcePmTraySink.4’ dialog, highlight the ‘Administrators’ group in the ‘Group or user names’ section.
10)In the ‘Permissions for Administrators’ section, toggle the ‘Allow’ option for ‘Full Control’
11)Press ‘OK’
12)Exit Regedit and run Acade
